Just installed the last version
Work really great with just a small issue, GCODE generation take time (progress bar froozing on 98% for minutes)
How could I install/run the 64 bits version on my Win10 64 bit ?
Thank you so much
Thierry
Thank you so much
Thierry
There is no 64Bit Windows installer of LaserWeb4. Try increase the amout of “GCODE GENERATION THREADS” under settings/gcode.
If you do raster engraving, you should also adjust the “TOOL HEAD BEAM SIZE” (in settings/machine) to something like 0.2mm.
