Internet Interface
Hello,
I am seeing a problem with the new network interface. My machine is up and running, and I can access it with the classic interface and that works OK, but it fails to upload new files to the SD. If I use the improved interface, it will move the files, but the controls for movement don’t load. That area is blank. I can also access the printer via Ponterface over the network, but when I want to move files with Ponterface, you must load them individually to Ponterface prior to saving them to the SD. Really slow and annoying. I can move files to the Sd card with the USB port, but my printer is downstairs and in the garage. I was hoping with the smoothie board network interface, I could load files from my desktop over the internet. So far it either isn’t working or its very slow. Anybody else experiencing these issues. My congfig and Edge file were updated 11/27/16. I have tried the interface with Windows, Chrome, and Firefox, all with the same results.
If you access the interface at the root ( http://smoothieboard_ip/ ) instead of at the sd card ( http://smoothieboard_ip/sd/webif/index.html ), does it then work ?
Does the computer have access to the internet ?
Ive had a similar experience where one interface works if I only ever load it once during a print but will lock up and require me to reset my board to access it again. Also have the issue where the controls never load
