Is a .080" pitch belt considered a GT2 ? GT2 is 2mm pitch and .080" is 2.032mm…
No, MXL is 0.080" pitch - http://products.beltcorp.com/viewitems/all-categories-pulleys-timing-pulleys-2/ys-timing-pulleys-0-080-pitch-mxl-pulleys-aluminum?
If you mix & match belts and pulleys you’ll likely end up with the belt jumping / slipping a notch every once and a while.
Cool thanks @Alex_Wiebe
