Is anyone having a problem running a job and it skipping steps in the file ? I am trying to run a very simple job and i am using cut2d to crate the file and it shows OK in when I running the job in chilipeppr job preview . but when I try to running the job it is skipping some steps. all my firmware is up to date and i am running JSON serial port 1.83 . My post p is tinyg inch mode . Any thought’s ?
here is a link to the file i am using , https://www.dropbox.com/s/j685ozlx62tzqht/test%203.gcode?dl=0
Please use 1.80 for now. We have discovered enough issues with the new serial port library in 1.83 that we are moving back to the original library.
thank you for replying
