Is G29C broken on the Redeem that ships with Umikaze?
It acts like it’s going to do a great huge amount of work, homing and probing then dies attempting the second probe.
I’m using this command:
G29C D140 C2 P8 S15 Z1 K1500
and G29C doesn’t display any help, it just takes off doing stuff and then dies.
If I don’t restart Redeem quickly then the Watchdog timer counts down and goes through its stuff.
Here’s the syslog messages from one of the attempts:
Sep 18 02:14:19 kamikaze redeem[2158]: 09-18 02:14 root ERROR No GCode processor for No-Gcode. Message:
Sep 18 02:14:19 kamikaze redeem[2158]: 09-18 02:14 root WARNING M557: Missing Z-parameter
Sep 18 02:14:19 kamikaze redeem[2158]: message repeated 2 times: [ 09-18 02:14 root WARNING M557: Missing Z-parameter]
Sep 18 02:14:20 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Y1 hit!
Sep 18 02:14:20 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Z1 hit!
Sep 18 02:14:20 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop X1 hit!
Sep 18 02:14:22 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop X1 hit!
Sep 18 02:14:22 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Y1 hit!
Sep 18 02:14:22 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Z1 hit!
Sep 18 02:14:23 kamikaze redeem[2158]: 09-18 02:14 root INFO Homing done.
Sep 18 02:14:23 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop X1 hit!
Sep 18 02:14:23 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Y1 hit!
Sep 18 02:14:23 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Z1 hit!
Sep 18 02:14:26 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Z1 hit!
Sep 18 02:14:26 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Y1 hit!
Sep 18 02:14:26 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop X1 hit!
Sep 18 02:14:26 kamikaze redeem[2158]: 09-18 02:14 root INFO Homing done.
Sep 18 02:14:28 kamikaze redeem[2158]: 09-18 02:14 root ERROR No GCode processor for No-Gcode. Message:
Sep 18 02:14:28 kamikaze redeem[2158]: 09-18 02:14 root INFO Using config file /etc/redeem/default.cfg
Sep 18 02:14:28 kamikaze redeem[2158]: 09-18 02:14 root WARNING Missing config file /etc/redeem/printer.cfg
Sep 18 02:14:28 kamikaze redeem[2158]: 09-18 02:14 root INFO Using config file /etc/redeem/local.cfg
Sep 18 02:14:34 kamikaze redeem[2158]: 09-18 02:14 root ERROR No GCode processor for No-Gcode. Message:
Sep 18 02:14:34 kamikaze redeem[2158]: 09-18 02:14 root INFO Using config file /etc/redeem/default.cfg
Sep 18 02:14:35 kamikaze redeem[2158]: 09-18 02:14 root WARNING Missing config file /etc/redeem/printer.cfg
Sep 18 02:14:35 kamikaze redeem[2158]: 09-18 02:14 root INFO Using config file /etc/redeem/local.cfg
Sep 18 02:14:53 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop X1 hit!
Sep 18 02:14:53 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Z1 hit!
Sep 18 02:14:54 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Y1 hit!
Sep 18 02:14:56 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Y1 hit!
Sep 18 02:14:56 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop Z1 hit!
Sep 18 02:14:56 kamikaze redeem[2158]: 09-18 02:14 root INFO End Stop X1 hit!
Sep 18 02:14:57 kamikaze redeem[2158]: 09-18 02:14 root INFO Homing done.
Sep 18 02:14:59 kamikaze redeem[2158]: 09-18 02:14 root ERROR No GCode processor for No-Gcode. Message:
Sep 18 02:14:59 kamikaze redeem[2158]: 09-18 02:14 root INFO Using config file /etc/redeem/default.cfg
Sep 18 02:14:59 kamikaze redeem[2158]: 09-18 02:14 root WARNING Missing config file /etc/redeem/printer.cfg
Sep 18 02:14:59 kamikaze redeem[2158]: 09-18 02:14 root INFO Using config file /etc/redeem/local.cfg
Sep 18 02:15:03 kamikaze redeem[2158]: [ 1505700903325 ]#011queueMove FAILED: axis 1 end position outside of soft limit (end = 0.18, max limit = 0.113)
Sep 18 02:15:04 kamikaze redeem[2158]: python: redeem/path_planner/Delta.cpp:408: double Delta::calculateCriticalPointTimeForAxis(int, const DeltaPathConstants&) const: Assertion `!std::isnan(firstT) && !std::isnan(secondT)’ failed.
Sep 18 02:15:04 kamikaze octoprint[448]: 2017-09-18 02:15:04,189 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
Sep 18 02:15:04 kamikaze octoprint[448]: Traceback (most recent call last):
Sep 18 02:15:04 kamikaze octoprint[448]: File “/usr/local/lib/python2.7/dist-packages/OctoPrint-1.3.4-py2.7.egg/octoprint/util/comm.py”, line 1827, in _readline
Sep 18 02:15:04 kamikaze octoprint[448]: ret = self._serial.readline()
Sep 18 02:15:04 kamikaze kernel: [ 6555.893231] watchdog watchdog0: watchdog did not stop!
Sep 18 02:15:04 kamikaze octoprint[448]: File “build/bdist.linux-armv7l/egg/serial/serialposix.py”, line 485, in read
Sep 18 02:15:04 kamikaze octoprint[448]: raise SerialException(‘read failed: %s’ % (e,))
Sep 18 02:15:04 kamikaze octoprint[448]: SerialException: read failed: [Errno 5] Input/output error
Sep 18 02:15:04 kamikaze systemd[1]: redeem.service: Main process exited, code=killed, status=6/ABRT
Sep 18 02:15:04 kamikaze octoprint[448]: 2017-09-18 02:15:04,257 - octoprint.util.comm - ERROR - Please see Home · OctoPrint/OctoPrint Wiki · GitHub for possible reasons of this.
Sep 18 02:15:04 kamikaze systemd[1]: redeem.service: Unit entered failed state.
Sep 18 02:15:04 kamikaze systemd[1]: redeem.service: Failed with result ‘signal’.
