Is it possible to configure the smoothieboard to use delta as a X2 axis
Is it possible to configure the smoothieboard to use delta as a X2 axis for the second motor for X? So that it can send same signal to both X axis motors?
http://smoothieware.org/3d-printer-guide#doubling-stepper-motor-drivers
I saw that which suggests jumpering them together but my question is basically if i can assign multiple pinouts to alpha through the config.
Nope, that’d be computationally extremely expensive, so it’s not likely to be implemented when a perfectly functioning electrical solution exists.
Thank you for your help quick help. Basically I have to run cables from one driver to another for PUL>PUL, DIR>DIR, ENB>ENB and so that only one pinout on the board sends signal, two drivers share the signal and send to two different motors all this sounds correct
