Is it possible to have multiple LED strips running separate code on separate pins from the same arduino? For example on a quadrotor, I’d have strips on each arm running code that monitors the separate pwm throttle outputs from the flight control board to the motors and slightly changes the speed of a wave or hue or some other value for each individual strip.
Awesome! That helps a lot, thank you!
