Is it possible to tell if MDF has formaldehyde in it,
Is it possible to tell if MDF has formaldehyde in it, or if it is safe to use?
MDF will give off fumes, however, if you have a good exhaust hooked up to an outside vent, you should not experience any problems. PVC is the big NO-NO, it will give off chlorine gas while being cut.
I can tell you that some plywood have a formaldehyde based glue in them…I would imagine that Mdf would be similar.
