Do you have the bottom bearing holders flush against the V-slot rail? There should be some space between the two. You will have to play with the amount of space until the motion is smooth. It shouldn’t require much force on the belt at all to move the bed.
@Zane_Baird That’s OK. I will let you get the next one
Also do you think I should modify the part to be sized with no adjustment to fit right against the vertical vslot? This has been a common problem for almost every builders. I left it with degrees of freedom so that perfect alignment could be obtained… but those freedoms come with complexity. I just figured not everyone’s prints are perfectly dimensionally accurate, so this freedom would give a little wiggle room.
@Eclsnowman Based on the problems people seem to have with it, it may be a good idea to make the part flush with the extrusion. If people are really printing parts that are inaccurate to the extent of 1mm, they are likely to have some serious issues with every aspect of the build involving a printed part… Plus, If it’s a matter of 100s of microns or so it’s unlikely it will effect the alignment too greatly (and if it does, there is always the option of sanding it down or putting a sheet of card stock between the two to get the right alignment).
could one of you measure your extrusion opening. im having a hell of a time getting the cover in for the plexi.i think my opening may be smaller.@5.28mm:( the vslot i have at its narrowest is 6.3 somethingdang it…
Yeah gimme a bit. Internet is all weird atm I can however slide the stuff in the rail sideways just not downwards. Mangled a piece of the stuff doing that lol
