Is there a good tutorial on how to trace a black and white image
Is there a good tutorial on how to trace a black and white image in Inkscape for vector engraving? After many tries I got it to work but it went over every line twice. If I remember right the double cut has to do with the line width. What does the line width have to be set at to get only one cut?
I am using a stock K40 and K40 Whisperer
Take your pick on YouTube. The secret is finding one that speaks to you!
Inkscape will trace bitmap images but like most tracers it will trace the outlines. So if you want a simple circle you need to start with a filled in circle. If the circle you start with is just the outline of a circle the tracer will trace the inside and outside of the pixels that form the outline of a circle. I think this is the most common difficulty people have with tracers. Like any tool if you know the limitations it is easier to work with them.
