Is there a mechanical auto focus add on for this little laser?
Is there a mechanical auto focus add on for this little laser? I am thinking of some sort of plunger that touches the material surface that would somehow either signal(LED) the correct focal length or if the Z was somehow automated just stop when it reached the correct focal length. I tried searching the group but found nothing.
I am working in a little device to use a visible laser to adjust the mirrors…
originally, the K40 has no Z setting and come with fix focal.
the lens focal is 50.8 mmm, the distance could be adjusted by raising the material manually with the help of a piece of wood mesuring about 50.5 mm (the difference is the material thickness).
