Is there a way to colorwipe fill_rainbow?
Not sure what you mean by colorwipe but this will move the rainbow effect through the leds:
void colorwipe()
//FastLED event scheduler
EVERY_N_MILLISECONDS( 100 )
hue++;
//FastLED rainbow function
fill_rainbow( leds, NUM_LEDS, hue, 7);
This part I know, but I don’t want the entire strip to come on at once, but rather one pixel at a time as the fill_rainbow function adjusts hue.
This will provide the colorwipe effect that you are looking for:
void colorwipe_dot(uint8_t chue, uint8_t wait) {
for (int i = 0; i < NUM_LEDS; i++){
leds[i] = CHSV(chue, 255, 255); // chue is the starting color. When 0, you start with red.
FastLED.show();
delay(wait);
chue+=10; // change to get desired rainbow effect depending on how many leds you are using.
This works well on a 24 led WS2812B ring When chue+=10. In your loop, you could put colorwipe_dot(0,100); which works well on my ring.
This is exactly what I needed thank you so much
i put it in setup() and put fill_rainbow in loop to get the effect i was looking for…
void setup() {
delay(1000);
LEDS.addLeds<LED_TYPE, LED_DT, LED_CK, COLOR_ORDER>(leds, NUM_LEDS);
FastLED.setBrightness(max_bright);
set_max_power_in_volts_and_milliamps(5, 500);
colorwipe_dot(0);
void loop() {
fill_rainbow(leds, NUM_LEDS, ghue, 1);
ghue–;
FastLED.show();
delay(100/FPS);
void colorwipe_dot(uint8_t chue) {
leds[i] = CHSV(chue, 0, 0); // chue is the starting color. When 0, you start with red.
FastLED.show();
chue+=1; // change to get desired rainbow effect depending on how many leds you are using.
fill_rainbow(leds, i, ghue, 1);
ghue--;
delay(100/FPS);
