Is there a way to make ESP8266 connect to a wifi which has WPA2-enterprise
Is there a way to make ESP8266 connect to a wifi which has WPA2-enterprise + PEAP enabled?
what I mean here is, to connect we have to provide ssid , username and password. I tried to google for a possible solution and found that esp8266 supports only WPA2-enterprise + EAP TLS
Please leave a comment, if you find a solution. I have the same issue.
You need a firmware that has the software support for that. The question is now of a quest to the appropriate firmware.
@Simos_Xenitellis Im usig nodemcu on ESP-12E module. Any workaround available to connect to WPA2-enterprise + PEAP ?
Which firmware mate?
I have gone through this thread several times… There’s no working example
