Is there a way to rotate a shape in laserdrw
Sure - grab one of the little boxes on the outline of the shape and move it around on the screen till the shape is in the alignment you want (ie place the pointer on the box on the bottom line and drag it up and over the top line to flip shape upside down)
@greg_greene I want it at an angle can’t figure out how or if it is possible
When I import an image the box the image is in is aligned with the margin of the work area. On the outline of the graphic box - each line has a little box, try grabbing the right hand box and pulling it down, the box should rotate. For text - its much easier, select text, enter your text in the text window then when done click on the work area, you will see the text box being drawn you can move the cursor at an angle and box will be drawn at that angle with text in it.
Yes I have been able to rotate text and images but not shapes not for sure what I am doing wrong
Ah I see what you mean - There may be a check box that makes the frees the shape to be rotated instead of drawn snapped to the grids. I haven’t tried that however.
When you have an object or shape selected, at the top of the program you will see X and Y coordinates then the size of the shape and then you will see a box with angle of rotation you can set.
You can also select an object , go to the top- Object menu pull down, Then Transformations and select Rotate. Or press Alt+F8 to pull up the rotate dialog.
@Jim_Bennell_PizzaDel you are my hero!
@Jim_Bennell_PizzaDel are you sure that is laserdrw I don’t see them when I just checked
Oh sorry I was looking at Corel , I haven’t used LaserDRW much. Just opened it up and I can’t find any options for rotating an object. Only thing I found was if you create a star shape with the star tool, the object properties dialog has a rotate option but the other shapes do not. It doesn’t seem like the best program for design. Might be good for bringing designs into it for lasing.
If you just want your whole design to be engraved or cut at 90,-90,180,mirrored there is an option in the engraving manager (Rotate) its normally set on do nothing. But if you just want to rotate one object not the whole design I suggest using Corel or something else like Inkscape or AI. Most programs will let you hold a hotkey while dragging a rotation to make it snap to 45 degree increments (usually ctrl+mouse1 drag to rotate or shift+mouse1 drag)
I do a lot of my designs in Inkscape and export as WMF for corelLaser. And in corel I use the WFM interpreter in the data settings. seems to work pretty good.
So what I had said earlier works in CorelLaser.
