Is there a way to sent laserdrw to start the second pass without the message popping up asking to start the next task?
Yep there is. What you need to do is as follows:
add first task to the queue, make sure that the tickbox “Starting” is not checked, then click “Add Task” button. The dialog will disappear.
add second task to queue, again making sure that tickbox is not checked.
continue adding tasks until you’ve added all that you want. Then when you are adding the last task, click the checkbox “Starting” before you press “Add Task”.
It should now do all the tasks in one go. Only other thing, there is an option for “Dialog” or “All Layers” in a dropdown box next to “Add Task”. I have mine set to All Layers. I have a feeling this is necessary also, but can’t remember specifically.
Oh, sorry, I just registered you said LaserDRW. That was for CorelLaser.
