Is there a way to set the connect-therm-E-fan-0 to a certain speed? I only need the fan to blow about 50%. Also related to that when I slow the speed on the fan I get a pwm whine, is there any way to change the frequency of the fan pwm to get rid of it?
What kind of hot end are you using?
M141 P0 F1000 S0.5
P is the fan number
F is the PWM frequency (I think 1,000 Hz is the default maybe?)
S is the on-time from 0…1
I’m using an e3d v6, but swapped out the stock fan for a blower fan. It has a lot more air flow, that’s why I’m trying to slow it down. Mark, 141 is for heated enclosure, 106 is for fans. Thanks for pointing out the frequency parameter though, I hadn’t noticed it. Tried several different values, and it doesn’t sound like they are having any effect.
Yes M141 on the g-code wiki page says heated enclosure, but that’s not what Redeem’s source code says:
And M106 doesn’t take a frequency parameter. https://bitbucket.org/intelligentagent/redeem/src/0dc7929320eec5f4573579aab4fb31ddaab8bbbd/redeem/gcodes/M106_M107.py?at=master&fileviewer=file-view-default
Thanks for showing me where the code was, it helped a ton. I tried out M141, but that wasn’t working either. Turns out set_PWM_frequency() isn’t implemented in Fan.py. I ended up just setting PWM.set_frequency(100) in the fan init. I also hard coded the fan to go on at half speed in Cooler.py, but it would be nice to have a way to modify it in the config.
