Is there a wiki or webpage that shows what’s best configuration for CP? As in minimal requirements for the SPJS and CP running on a local machine?
I ask this because when I redesign the host controller for my machine I replaced my RPi B+ with a ITX dual core machine (2.2ghz), 8GB of ram and a 60GB SSD. Its running Ubuntu. All day today, When I ran a job. It would run the first 4~6 lines of gcode, then pause. After fiddling around for a couple minutes, I clicked on feed hold then it would start again. From that point on It would do this randomly on different gcode files. Multiple times during the job. (I’d say a avg. of 2 times per job)
The other issue is that CP would lose it connection with SPJS (which is running locally on the machine.) but yet, @Riley_Porter_ril3y pendant control is still active and connected to the same instance as CP and still controls the CNC (As in, they were both connected- But then CP loses it connection (claim that no serial port is available) - But the pendant control is still working.) I’d have to kill and restart SPJS a couples of times to get it to see it again. This has been tested without the pendant app running. Same behavior. As a side question, When you restart the SPJS from CP- Is there a way to get SPJS to restart the same instance is running vs. killing it and starting it again daemonized? I leave it active with -v in a terminal so I can see what’s going on. And when it re starts, there is no way to see what it’s doing without kill -9’ing the restarted instance. If it wrote a rolling log of some sort, then I can just tail the log.
And lastly, Yesterday I was doing a aircut. I let it run for about 45 mins then I stopped it by clicking ‘stop’ in the gcode widget. Then I went ahead and wiped the buffer. The behavior I saw was it went far left on Y, Then up on Z, Then back the same distance on Y (all at different feed rates and motions that not in the gcode file) Home itself then went back where it should have been when I clicked stop. Doesn’t matter the gcode. And it repeatable.
I’ve upped the nice priority on the SPJS to -10 and have firefox running in kiosk mode. This machine does nothing else.
TinyG2 build 83.09 - SPJS 1.80 - Ubuntu 14.04.2 LTS
Sorry for the long post. Trying to figure out to get it to work optimally with minimal upkeep.
