Is there an easy way to boot #Ubuntu on #BeagleBoneBlack that doesn’t require downloading an image and reflashing the board?
https://www.akirisolutions.com/products/beagle-bone/ubuntu
this works well http://www.armhf.com/index.php/boards/beaglebone-black/
I’ve run Debian 7 and Ubuntu 13 direct from SD. only thing that is pain is have to hold down boot. Jason or @Gerald_Coley is there a hack for that?
Sure. Just remove the MLO file from the eMMC.
If you add a uEnv.txt to the SD card, the on-eMMC u-boot should read it for its configuration if it has the default install on it.
But that dictates that Uboot comes from the eMMC and does not use the Uboot from the uSD.
thanks! do you have any idea if eMMC is faster than the microSD slot? (say with a SanDisk class 10}
It is capable of being faster if the SW supports the 8b interface. Not double but should be 25% faster +/-.
thanks, I’m going to be using this one: http://www.amazon.com/gp/aw/d/B009QZH7D8 (just came today)
@Andrew_Bradford sure I will give it a try. I followed http://armhf.com instructions to flash Debian to eMMC so I can now choose to run the same image from SD or eMMC. Should make a good test
