Is there any controllable (warm and or cold) white only LED-Strip out there?
I doubt it simply because the only difference between the two (Cold, Warm) frequency’s is a coating on the “warm” LED’s…
Maybe I wasn’t clear, I don’t care if it’s warm or cold white at the moment. I’m just interested if there are controllable white strips available. I want to control which led lights up, but I don’t need RGB, without shred a normal (ip65) white strip into pieces and wire ever separate LED.
@Max_Heine if you value time more than money, get the adafruit RGBW strips, and either use RGB together for one white, or W for the other white. Yes, you’ll pay more than needed, but then again I haven’t seen addressable LEDs that were white only.
Found 5050 LEDs, but can’t seem to find strips: https://www.adafruit.com/product/2375
APA102 in warm. They also have cool and also in 144pixel/meter.
I can’t remember where but I’ve seen these listed in AliExpress too (for cheaper). Search for something like “WWW Strip”
Thanks, that’s exactly what I was searching for. Also “APA102” at AliExpress showed plenty offers.
