Is there any way to test motors with out having the hot end thermal sensor hooked up?
I’m using marlin firmware.
i am currently trying in pronterface and getting an error saying to use M999 to reset.
M999
SENDING:M999
Resend: 1
Error:0
: Extruder switched off. MAXTEMP triggered !
Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
You can also just put a resistor on the thermistor pins. A 47k will put it in line to allow you to bypass the firmware safety Use at your own risk, don’t heat anything that has that jumper
My hot end is on a connector and I have a dummy one which has a 4k7 resistor instead of the thermistor. I plug that in when the hot end is dismantled and I want to do something with the motors.
