Is there anyone here who might know about spectrum analysers?
I’m building an LED covered jacket, which I want to function as a spectrum analyser. I will be using ws2812b strips for the LEDs, and a teensy 3.2 to control it all.
Naturally, the PJRCSpectrumAnalyser example is the first place I look for code to start with
I was wondering a couple things
Can I get the same effect without using a smartmatrix? (Or any pre built matrix display) I plan on using strips, so the frequency bands can be dispersed all over my jacket.
Can I accomplish this effect without the octows2811 adapter? My “matrix” will be 6 pixels tall x 18 pixels wide (18 strips of 6 LEDs each), so 108 pixels total.
@Post-Master_Sodium - Use the Search Community box on the left of this webpage with the term: spectrum. Also, search with the name: Matt Camp. Matt Camp has a great top hat spectrum analyzer in which he shares his code. Also search with: spectrum deamcoat. Robert Atkins shares the code for his amazing dreamcoat with spectrum analyzer. These searches and projects should be helpful to you.
It uses a Teensy 3.2 and a microphone, very easy to wire and get started.
Also, where do you plan on using your jacket? I’ve had terrific success with sound reactive projects in small setups in the 33-50 decibel range, but I’ve had trouble getting good results in festivals over 70+ decibels. It’s much harder to tune. It seems like all the frequencies overload each other or something. Just so you know when you do your tests.
Thanks @Ken_White , I was using the android app, so I didn’t have a search function, but logging in through the web works, I will definitely look those up!
@Franck_Marcotte I hope to have it usable for oregon eclipse (music festival). I do know the fft tutorial you posted. I was planning on using that first, then working it out so each strip is a frequency band, and looks more like the common specrum analyser.
I’m not sure it will work as good as I hope, but I’m going to add a potentiometer to adjust the dB range, so I can (hopefully) fine tune it to where I’m at. We’ll see how it goes though, lol.
