Is there anywhere I can find on configuring the stock software?
And I seen a picture some where showing one entering the serial number off the main board.
Found the board model needed to be changed.
is it common to have to restart corellaser draw after each project?
my function toolbar in top right corner disappears and you have to restart software to get it back.
No, you will find that the toolbar does disappear, but there is an icon down the bottom in windows near the clock. You can right click it and access all the functions (cut/engrave/start/etc) that are on the toolbar.
I have a bunch of config screenshots that I will share here in a minute. Bear with me while I find them & link them.
The icon bar in CorelLaser disappears from the upper right and tucks itself away in the lower right corner of the Windows taskbar.
Thank you. I did get it to finally engrave. Till my power supply to my fan died. Now need to find anither 12 v power suppl
You will find a handful of screenshots (with comments I made) here: https://drive.google.com/folderview?id=0Bzi2h1k_udXwUWJwM29COUNxSUU&usp=sharing
@John_Austin Is this a new machine? If so contact the seller about faulty PSU & ask for a replacement/refund to cover the costs of getting a new one.
Its a 12 volt power supply that i had to run a fan that i switched out with the stock fan. I need to see if the stock power supply for the laser has a 12 volt output.
thanks for the link. I will check them out in a few.
@John_Austin Oh right, for the exhaust fan? I misinterpreted. I thought the laser PSU died because it’s fan died. Lucky it wasn’t that.
@Yuusuf_Sallahuddin_Y
Going to check and see if there is a volt on the PSU that i can use.
Is there anyway to pause the laser while it is running?
First successful runs
Explore John Austin
@John_Austin There is a pause option for whilst the laser is in the middle of a task, although it has a slight delay before it actually pauses. In an emergency, I just turn the laser-enable switch off to prevent disaster. You will find the pause option either on the toolbar or the right-click menu of the system tray icon.
First successful run looks good. Looking at it closely I have a feeling that either your alignment is not precise yet, or your material wasn’t level along the whole engrave. I say this because the words “This is a test” seem to be darker at the beginning than at the end. Could just be the wood or photo too…
@Yuusuf_Sallahuddin_Y Hi, I am an owner of a new “K40” and going thru the learning curve. I am using CorelDraw X7 with “CorelLaser” in Windows 10 and I am having the same problem with the CorelLaser toolbar disappearing [from the upper right] after each print job. I can’t locate it anywhere and my fix has been closing CorelDraw and reopening through CorelLaser each time. I have tried opening Corel Laser without closing CorelDraw, however it does not work that way. Any help would be appreciated, I must be missing something! Thanks,
Tim
@Tim_Delaney ​ lower right corner of your Windows desktop is the date/time. If it’s recent windows there’s also an upward pointing triangle/arrow. Click that and you’ll see all the running things that hide their icons when running. One of them is your CorelLaser. Right clicking will bring up the icons that disappeared from Corel when you started the job.
@Tim_Delaney as Jim mentions, you should find it down near the time/date. Sometimes there is an arrow (which Jim also mentions) that when clicked will bring up a little popup with all the apps that have an icon in that area. I’ve personally set Windows to always show all apps that are open down there.
@Jim_Hatch Have you also noticed with the CorelLaser in Win10 that the stupid notifications that Win10 does for the plugin (e.g. “monitoring last progress”) sometimes cover the popup menu & make you have to wait for the notification to get lost before you can do anything? That was seriously annoying me at times.
@Yuusuf_Sallahuddin_Y ​ yeah, the notifications float there for longer than it takes to read. Sometimes you can hit the ESC key and it will go away. Depends on the app.
Hi
Thanks for the tips, I seem to have it sorted out thanks for keeping me pointed in the right direction. I think part of my problem might be an overzealous version of Macafee on my laptop.
In any event, moving on the the next bug! Thanks again!
