Is this the engraving speed i should expect after upgrading to smoothie?
Running cohesion3d mini and lw4 via usb at 150mm/s
Try LightBurn - the 30 day trial is free and unrestricted, and the GCode sender is much faster. Smoothie, due to processing speed, will run 250dpi at roughly 80 to 100 mm/sec, and GRBL-LPC will run at roughly 200mm/sec or better.
What Lightburn said. What you’re seeing is the stutter of LW4 not sending the data fast enough. Try that software.
Info and Downloads available at http://cohesion3d.com/lightburn-software and at http://lightburnsoftware.com
http://cohesion3d.com/lightburn-software/
Thanks.
Just installed and run lightburn, but cant control the Y axis…
I have had an issue with the Y axis on my cohesion 3d mini that was solved by changing the config file to use the A-axis instead, but it seems like that gets overruled when running lightburn
- All i get is a strange roaring when jogging the Y axis.
200mm/s seems quite well. I hope that i will get there someday
That shouldn’t be the case - we have the same issue with our test board, in fact. The Smoothie config file change works for us. GRBL-LPC required rebuilding with different axis definitions, as it does not use the config file.
What issue? And if you remapped Y --> A socket pins in config.txt the controlling software should not change anything.
You might need to lower the acceleration or rapid speed for in your settings. LightBurn uses those values for rapid moves, or the speed value set in the “Move” window, tabbed behind the cuts window, for click-to-move.
It sounds like the Y axis being driven too fast and missing steps - that would make the sound you describe.
And to be clear, I sent Lightburn dev one of our boards that failed QA where the Y socket was not working properly, and they just changed the pins over to the Z socket and everything works… but we test everything we ship, so I do not think /hope your board has this issue.
Ah! Correct - should’ve stated that.
Maybe a good nights sleep and a fresh mind will help me
Ray#
I had the problem with Y-axis not moving. Tried changing the X and Y drivers, but still the same, so read this forum and tried the solution with remapping to A-socket. Works like a charm now. (it also did out of the box, so nothing wrong with your factory test)
Lightburn#
I run smoothie driver. Havent really found out what it takes to run GRBL yet.
New firmware on the board, and changed settings in lw4 or lightburn. Is that all?
I tried changing speed settings from 300mm/s down to 50mm/s when jogging, but no change. I will try again today and keep you updated with a video when i get home.
Both#
Thanks for your feedback guys
That’s very strange - LightBurn, under the hood, is just emitting either rapid moves, or G1 moves. It’s possible that you have your Smoothie rapid setting too high. That would be “default_seek_rate” in the Smoothie configuration, set in mm/min. I think the shipped default is 4000, but I’ve probably set mine to 6000 at least, probably 9000. If you set that too high, you could get the grinding. Maybe LaserWeb applies a feed rate to the rapid moves too.
@raykholo Please be correct! It’s not LW4 that can not deliver data fast enough, it’s smoothiewares serial “protocoll” and the used mbed serial driver that slows down the communication. We can deliver more than 200mm/s at 250dpi with grbl-LPC!!
What some other software does is using a workaround (push the whole file to the USB driver) with the downside of loosing control to stop/pause the machine mid job immediately. We can’t accept such a behaviour.
LightBurn still allows pause, though you are correct that there is a delay as the plan and serial buffers empty. Stop is immediate, as it should always be.
@cprezzi NO you are still wrong. It is NOT smoothie serial protocol and we do not use mbed usb serial either. I have proven over and over again the issue is the HOST (PC) usb drivers. There is a delay when it reads the ok, this is not anything we can do about. the http://fast-stream.py proves that as it decouples the sending from the ok. Once and for all please get your facts straight. I am getting very tired of your consistent refusal to accept facts.
+Wolfmanjm The send->ok is your original “protocol” and http://fast-stream.py is just your workaround that sacrifice immediate response. Is that wrong?
And once and for all: STOP stalking me with your FAKE FACTS!
It’s FACT that the same hardware with a different firmware can deliver twice the pixel rate with the same host. You just never can accept faults on your side.
Regardless of where the fault lies, a solution exists that is easy to implement, we’ve done so, and customers approve. For us it really is that simple.
We’ll be investigating a number of updates to our streamer to allow for a more or less instant pause on Smoothieware even with the decoupled streaming, and already have this working with GRBL and GRBL-LPC.
@LightBurn_Software Sure, if you can live with the delay, you can use the workaround (no problem for raster engraving).
But LW4 is also used for CNC-Milling where we need a synced process and cannot accept a delay of many moves. That’s the reason why we don’t implement the workaround.
I would simply provide that as an option, allowing the user to choose.
@cprezzi “fake facts” oh really, you are the one that has stated blatantly incorrect information, and if you peruse the original Issue on this that we solved with DarklyLabs, I give the “facts”. One more thing the ping pong protocol is not a smoothie protocol, it is the standard reprap protocol. You really need to do some research before you go insulting other developers. The issue is clearly (and documented in the USB drivers themselves) that Macs and Windows USB serial driver waits for several milliseconds before returning a read request even if there is data in the buffer. This means the read of an OK is delayed enough to slow the ping pong protocol (again the STANDARD) in most cases. Linux drivers do not seem to have this builtin delay, and is why things work much faster in Linux. FWIW the delay is there to try to fill the USB buffers which have a minimum size of 64bytes. I suggest you do your homework.
To be honest I cannot be bothered with you, (let alone stalk you!) but I will correct your incorrect statements when you make them.
