I need help I have checked the configuration file and that looks all good, I have 0 volt at the green connector screws, so my thought is that something is wired correctly… can someone provide me some images of a printer set up board and any help would be appreciated.
Are you providing power to the mosfets power input ?
Did you read http://smoothieware.org/3d-printer-guide ?
I read the guide several times and the power to the Moffitts is what I thought the problem was, but I am not sure how that is supposed to be wired… can clarify what needs to be wired to what…
It really is all explained in the guide, and thousands of users read it and successfully get their printer to work, so I recommend you read it again with a clear head.
The basic idea is :
- You connect your power supply to the mosfet input
- You connect your heating element to the mosfet output
And that’s it.
First thanks for the simple answer about connecting the mosfet to my power supply. But sadly that was all I needed for help, the rest of comments were un necessary, if everyone else in this community has as snotty of an attitude as you , I can tell you that I will not be asking any additional questions.
How was this snotty ?
We put a lot of work into writing the documentation, and pointing out that everybody else is able to retrieve the information you ask from it, is relevant to answering your question.
Nobody was trying to mock you in anyway here, just point out that if you look it it carefully enough, the information is there … Not exactly sure why you are taking it the wrong way …
