It is solved!!!!!!!!! G28 all has corrected
The help is necessary. There was a problem with axis Z. Initially at start from a 0-point the table rose on the set level, but at a command home cursors started to howl and were stopped, has changed зачение lines
#define HOMING_FEEDRATE {5060, 5060, 4*60, 0}//set the homing speeds (mm/min)
On the following
#define HOMING_FEEDRATE {5060, 5060, 3*60, 0}//set the homing speeds (mm/min)
Engines have ceased to be stopped and howl but, at command giving home in Pronterface there is a following, shaft start to rotate, and through some moment change a rotation direction. Having made “N” turns on lifting they besides these change a direction on necessary but any more докручивают before operation endstop “N” turns. Command М114 shows that all in position the house. Endstop and conducting are serviceable. What can it be and how it to correct?
