It lives! Still tuning print quality, but so far I’m very happy with the results
Looks like that X axis can lose quite some weight without losing any noticeable strength.
It sure could! The plan was to get something up and running that was accurate, cheap to machine, and low risk. Then I can print improvements to the design myself …
Actually, despite the mass, it works like a charm and can print quite quickly without shaking the frame noticeably.
Hi David, Excellent work on this build - Like all the CNC’d parts particularly :). You’d be well placed to drill some 50mm (or larger holes in the Y bed plate) to reduce weight and it is worth it as the lighter the build platform, the higher you can set you acceleration and that makes a big difference to your build time when printing dense infill or complex models.
Hi Tim,
Thanks for the advice! Actually, I have another slight issue with the Y-plate - the assembly has a little bit of play which means the print surface doesn’t stay perfectly level (no support at the sides). I realise with hindsight this is an obvious flaw in the design! When I get around to doing a version 2 of this assembly, I’ll also incorporate your suggestion for a nice bit of weight reduction.
Thanks again!
David
