it seems I can’t use 3mmX12mm_Buttonhead(McMaster_92095A183) to screw in Endstop Subminiature Switch … Is anyone also has this problem ? or I need to re-drill a hole ? Thanks
I remember asking the same question
Drill them to 3mm.
@Maxime_Favre Hi Max, do you put an alumimun plate under your power supply for secured? and also how did you organize the cables and wires ? I like your printer final clean outlook. Thanks
I didn’t put anything under the PS but mine is probably smaller and lighter than the BOM’s one. For cable managment I used 20mm wide cable trays under extrusions and cable chains. Scroll down this group for more pictures.
Lots of zip ties and cable sleeving will give it a nice clean look. I just directly glued my power supply to the acrylic and it held up pretty well
My machine after completed and the underside. Somewhat clean and managed. I have also added panes to the sides and back to reduce drafts
