Itching for a test flight.
I know that this has been done before, but was wondering if anyone in the community has tried and succeeded. I’m using a Da Vinci 1.0 ( so, so far this has been complicated).
Let us know how it goes. I’ve got two motor & fan units like that, they sure move some air!
Hii kiya tum mery help karonge
They do seem to give good thrust. I’m just worried about airflow due to raft material on the upper wing surfaces, and the fact that the printed wings (10% infill) may be slightly permeable.
Mujhe bus intna pucha tha ke yeh apne kiss trsh banYe pleass
@Fahroddin_Saifee I’m sorry but I’m not quite sure what you are saying. Google translate is not helping either.
One of my main issues right now is the raft material on the top sides of the wing sections. Does anyone have any good solution for removing this texture?
Do a search in the community for acetone vapour smoothing. You could mask off areas you don’t want smoothed.
I’ve tried cold acetone vapor smoothing, but don’t have the equipment to try the more dangerous hot technique. It did smooth the part quite a bit and gave me a nice sheen, but also turned out slightly hilly where there were thinner areas of material. I’m thinking if I can’t remove the small ridges they would simply result in a more gradual bumpy surface. Also, the last time I attempted the cold method it didn’t work for some reason…not sure why.
