Iterating on the “boat” for the XY gantry.
Got an E3D Aero. Once assembled, the first thing was to print a test mount, to find the center-of-mass … by hanging the assembly from a bit of string.
The result was a bit simpler than I expected. The center is just within the front-center of the motor. (Are stepper motors more dense in the front?)
Note I have a pancake motor on order from E3D. Is the heavier motor needed for higher print speeds? Is the smaller motor adequate? Would the smaller motor with a bigger gear be adequate? Dunno.
The notion is to as far as practical to align forces. If the belts pulling the print-head are pulling “through” the center-of-mass, the print-head will not want to yaw or pitch - which could mean rigid with lighter structure.
So I turned the print-head “sideways”.
If the nozzle is also near the X-axis (the E3D nozzle is slightly offset) then torsional load on the XY plane is less. (There is still torsion in Z.)
The problem with this approach is that the “boat” takes up space in X, limits the range of travel, and thus the X dimension of the print area. Almost certainly a bad trade-off for slower printers, but perhaps worthwhile at higher speeds.(Arguably, for the same-sized frame, gain a bit in Y.)
The “boat” is sized for the print-head assembly. A bigger print-head means you need to print a bigger boat. Suspect this is a non-problem.
Ended up splitting the boat into inner and outer frames - not as I expect this to be the final design, but to support iteration. Do not want to reassemble the nice E3D hardware every time I revise the boat.
As a first iteration, have the boat riding on square tube. Riding on round tube under torsional load, would expect the assembly to want to pitch and yaw. On square tube, perhaps less?
The above is a bunch of theories … that need test.
Need to find some square tube of appropriate size. Something cheap and easy for a possibly-throw-away iteration. Then fabricate the slider/ends to match.
The fit between the print-head and top of frame diagonals is … complex. Could tweak this to gain more print area - but not for this build.
Given that the motor is a pretty solid hunk of metal, running structure around the motor is a waste. Tried to unscrew the back of a stepper … but mine really do not want to come apart. Later.
