Iterations on a corner. Printed with 0.3mm layers at 150mm/s and 20% infill. Surprisingly(!) solid for such a light/sloppy print.
Note the ultimate aim of my exercise is fast printing with a fairly large (~500mm cube) volume. That means a rapidly accelerating print head. That means the frame needs to be extremely rigid.
To my eye, a metal corner cube on the end of a 500mm lever is over-matched. The usual small triangle braces or L-brackets for the inside corners are also both over-matched.
Using extrusions as part of a linear bearing (in Z at least), the inside-corner braces cut into the print volume.
As the extrusions are aluminum, I want the major braces to be aluminum. Metals with different rates of thermal expansion are a source of error I want to avoid.
If I had a CNC router (a project for another month), I might cut side-braces out of sheet aluminum. For this iteration, strips of aluminum with a hole in each end are something I can readily fabricate. Tedious to assemble and align, but possible and perhaps sufficient.
My aim is to have a frame of rigid triangles. With such a frame, plastic corners might be sufficient.
This is seat-of-the-pants engineering. Also my Amazon deliveries included a laser pointer. I expect to fabricate a clamp for the pointer, and collect deflection measurements on the frame (with the laser projecting ~30 feet to an opposite wall). Also received a linear slide, linear bushings, and an assortment of pulleys, gears, and bearings to test and measure. Maybe not just seat-of-the-pants.
Printed plastic corners can serve quite a lot of purpose, and simplify the overall design - if they work. The corners could also serve as… Feet to elevate the frame off the desk. Stand-offs for a printer enclosure. Mounts for stepper motors and worm screws. Supports for belt/pulleys. Could potentially reduce the BOM and simplify fabrication.
At least the above is a bunch of theory. On to the next experiment…
