It’s clear that I can work faster with some zero switches. @Brandon_Satterfield What have you worked out for the R7? I saw some cut parts. Is the switch file uploaded? Is there a picture of switch placement?
Hey bud, yes they are included on the file now. The first one I did though I just drilled in place on Y.
Took the Y end caps off and ran the X off the Y beams. Did Z there. If you have access to the back of your machine you can probably do this without removing anything.
Nothing too fancy man, as long as the y click and are on the right side for your chosen home, it’s done.
I was looking at this link and didn’t see the new holes:
