It’s necessary the SN 74HCT245 IC to shift 3.3v to 5.0v on wemos d1 pro on D3 PIN?
I noticed that if i connect a 5 meters strip led with 30/40cm data wire to D3 of wemos all effects are perfect.
If i extend the data wire from 30/40cm to 3/4 meters the strip leds flickeing?
So, i ask, it’s possibile/sure that with a shift level (N 74HCT245) the problem is solved?
I tried the i2c level converter (like in image) but the flickering is the same.
Why?
Thanks a lot
