It’s new Slic3r day again!
http://slic3r.org/releases/0.9.8
So, let’s hear what you have to say about it…
Just downloaded, but I’ve been waiting to try the custom toolchange code command (which we requested) for dual extruders. I find that cooling an extruder 5-10 degrees while it’s not in use makes a huge difference for ooze (and it also makes it possible to wipe when switching.
Does the skirt support both extruders yet? That’ll take 75% of the ooze away if you make the skirt go all the way up.
I think it still only does it for the first layer.
Totally fixed the “bumps/pimples” issue awesome!
How does it do this Jay?
@Robin_Gingerich https://github.com/alexrj/Slic3r/commit/68fc91d854ca7cc61b5b53af71574ec135f99916 (offset miter limit was changed. I confirmed by reslicing the part I had issues with on 0.9.7 and the slices were perfect
Slicing is definitely better, did you have to change any settings @Whosa_whatsis as I believe values like retraction were changed. Mine says 1.2 instead of 1.3
It shouldn’t change any of your profile settings, except maybe if you’re using the default ones.
