It’s not my photo, but I have the same problem.
Look on flat top with 3 holes, that printed like vertical, so look on small wave on all way from left to right.
What is it?
How to make it flat?
It’s looks like wrong stepper current, but how to calibrate this?
Are you printing infill without an angle? Without an angle you might be getting waves because the line position may be restricted to multiples of the stepper. Print at 45 degrees and this might go away. If it’s still present you may need to turn up the extrusion by a few percent to get more fill and flatness.
Backlash
It’s because the belts are slightly flexible. This means they are acting like a spring when you accelerate or decelerate your print head. Increase the tension or decrease the acceleration could help.
Jup, jerk/acceleration might be a part of the problem, but likely the current setting of your stepper drivers (just try a lower/higher setting and see what happens) also plays its part. Ans as usual, check that your belts and pulleys are tight.
Solution found.
Lower down current on X & Y driver as much as possible (now it’s impossible to destroy some planet with force of driver as that was before)
I made just a little bit more than need my end-stop press. Wall made a lot better but still not ideal (I don’t touch E-drive current on my direct drive it’s impossible to lower this)
