I’ve been experimenting with 3D printing surfaces, here are my findings which you might find helpful and/or interesting: https://3dprinterchat.com/2016/02/3d-printer-surface-comparason/
Note on glass availability: any place that does picture framing has the ability to cut glass.
You might want to add Coropad and Printbite to the list at some stage since those compete with Buildtak
PLA sticks beautifully on heated glass. One of my favorite beds.
I use strips of 3M-150 Automotive Tape on the bed.
http://www.shop3m.com.au/3mtm-150-automotive-masking-tape-24mm-x-50m.html
This tape is very tough and each application lasts for ages - basically until I damage it with a sharp object. Usually I replace the tape every 3 or 4 months.
I apply UHU glue stick on top of the 3M-150 tape which I then firmly rub over with a spatula until it gets super tacky. Initially the glue is very slippery, but up to a minute of rubbing later the slipperiness has all gone.
Rubbing over the UHU glue makes it extremely tacky - so tacky that I need to take care with the objects I print - they must have minimal contact with the bed or the only way to get the print off is to cut the 3M-150 tape off first.
I’ve started using Printbite, flipping brilliant no messing about changing bed type for different filaments.
