I've been having trouble using WS2812s with the DigiSpark.
I’ve been having trouble using WS2812s with the DigiSpark. I get compile errors. I have no trouble using WS2801s. They compile and run correctly.
Any input would be greatly appreciated.
Blink.cpp.o: In function ClocklessController_Trinket<(unsigned char)0, 4, 10, 6, (EOrder)10, 50>::showRGBInternal_AdjTime(int, bool, int, unsigned char, unsigned char const*)': /Users/paulio/Documents/Arduino/libraries/FastLED_master/clockless_trinket.h:83: undefined reference to timer0_millis’
Sketch is FastLED Blink.
Using the DigiSpark Arduino IDE.
FastLED 2.0.
#include “FastLED.h”
// How many leds in your strip?
#define NUM_LEDS 6
// For led chips like Neopixels, which have a data line, ground, and power, you just
// need to define DATA_PIN. For led chipsets that are SPI based (four wires - data, clock,
// ground, and power), like the LPD8806 define both DATA_PIN and CLOCK_PIN
#define DATA_PIN 0
#define CLOCK_PIN 1
// Define the array of leds
CRGB leds[NUM_LEDS];
void setup() {
// Uncomment/edit one of the following lines for your leds arrangement.
// FastLED.addLeds<TM1803, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<TM1804, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<TM1809, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, NUM_LEDS);
FastLED.addLeds<WS2812, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<NEOPIXEL, DATA_PIN, RGB>(leds, NUM_LEDS);
// FastLED.addLeds<UCS1903, DATA_PIN, RGB>(leds, NUM_LEDS);
  // FastLED.addLeds<WS2801, RGB>(leds, NUM_LEDS);
  // FastLED.addLeds<SM16716, RGB>(leds, NUM_LEDS);
  // FastLED.addLeds<LPD8806, RGB>(leds, NUM_LEDS);
  // FastLED.addLeds<WS2801, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
  // FastLED.addLeds<SM16716, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
  // FastLED.addLeds<LPD8806, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
void loop() {
// Turn the LED on, then pause
leds[0] = CRGB::Red;
FastLED.show();
delay(500);
// Now turn the LED off, then pause
leds[0] = CRGB::Black;
FastLED.show();
delay(500);
This line works:
I haven’t had a chance to do digispark testing - it sounds like the digispark folks changed how they’re tracking time - which breaks the ws2811 code, which attempts to adjust the time to account for the disabling of interrupts while writing out data.
I can try to take a look at it over the next couple of days (I don’t have the digispark software installed).
Hi Daniel. No worries. I was under the impression that the DigiSpark was supported and I was just doing something wrong. I would love it if the smaller WS2812 code worked but the larger WS2801 code would make it a good challenge. Please don’t go out of your way just for me. Thanks for everything you do for us.
Best of luck
