i've been meaning to give PEI a try for a while now,
i’ve been meaning to give PEI a try for a while now, for a more “fire and forget” kind of printing flow.
the setup i have now is a mic6 6mm thick plate (250x250mm) - that depending on what material i’m printing gets a layer of either modpodge or carpenters glue (mixed with water).
this works extremely well for most materials i print, giving a great bottom layer finish (very similar to printing on glass), and extremely good first layer grip.
the caveat being that it has to be re-applied/cleaned every ~7-10 prints or so, and that some prints are harder to remove than others. this sometimes makes the whole process of removing the print and having to re-apply/clean taking up quite some time.
i’ve heard great things about PEI for PLA, PETG and taulman’s Nylon variants which are the materials i mostly print. although, a friend who purchased a PEI sheet (too thin i think) had many problems with it (with which i tried to help).
so i’ve got a few questions which i’m hoping some of you may be able to help:
  1. is there a recommended thickness to get? on the reprap wiki i can see 30mil (0.8mm) is the recommended and most common thickness - does anyone have any experience indicating differently?
  2. i’m trying to decide between buying some 3m 468mp tape adhesive to stick it to the plate and using crocodiles/bulldog (is that what they are also called abroad?) pins - like you would with a glass plate, and have the PEI sheet removable, so i can remove prints and handle them more easily. does anyone have any experience doing this? would a 30mil (0.8mm) PEI sheet be thick enough for that? or should i just forgo that dream and use the 3m tape?
Second the use of 3M 468MP with PEI–I originally planned to have just the PEI sheet clipped to my aluminum plate but it was impossible to keep it flat; best way to do it is to adhere it directly on your aluminum bed or a sheet of glass to clip onto your bed.
You might have to crank up the heat slightly to account of the different bed surface and reduced thermal conductivity.
thanks @David_Sherwood & @Ishaan_Gov - would you say there is any advantage to getting a 60mil (1.6mm) thick PEI sheet instead? do you think that could be used with clips on the aluminum plate then?
or should i stick (pun intended) with 0.8mm and 3m 468mp tape?
@Tom_Keidar , I would just go with the 0.8mm and the adhesive tape–no guarantees that the 1.6mm one will be flat enough;
But do consider making your PEI platform removable either on glass or aluminum; there have been a couple times where a removable platform was really useful
that kinda puts me in a conflict, since i’m trying to stay away from glass. one of the reasons i moved to a mic6 aluminum plate was the shortcomings of glass (breaking, uneven heat distribution, longer heat times and higher temps needed) - all of which i can happily say the aluminum plate solved.
my gut is churning thinking of permanently attaching the PEI sheet to the aluminum bed (in case i need different adhesion materials for special filaments, or just for easier cleaning and removal of prints) - so i was hoping perhaps a 1.6mm thick sheet would do.
thanks for the info so far, it’s given me much to think on - i’m trying to decide whether to forgo the entire thing or perhaps get the 1.6mm thick one as a gamble and see if i can devise a way that is both detachable and keeps it tight on the bed.
how flexible would you say a 1.6mm sheet is anyway?
