I’ve been messing with this fully enclosed, direct drive, plywood version for a while (OnShape access on request).
While I’m fairly happy so far, I’m stuck choosing the Z lift mechanism.
The belt lift is simple and cheap but seems to be out of fashion at the moment.
I’d really appreciate your thoughts on Z lift options!
Belt lift has the advantage of being cheap an little chance of Z-ribbing like lead screws. The downside is it can stretch and tends to fall with gravity when steppers aren’t energized. But I think a geared stepper could solve the falling issue and an adjustable idler could handle tension issues.
Eric - a geared stepper raises the price close to a the leadscrew option, though keeps the simplicity.
I feel there has to be some sort of simple rate limiter (fluid/air) solution. A big lump of soft foam should do well enough also
Belt stretch is something I hadn’t considered! Do you think two 6mm belts will be sufficient for a 400x200 heatbed?
I wouldn’t do more than a single start lead screw. Dual and four start lead screws have the risk of back driving (falling) when the z motor turns off. They’re harder to find though.
I’ve got the rubber band lift Z and will be swapping it out for lead screws…it’s too fiddly. The bed is near the limit of what the system can lift without slipping, and the belt lifting the bed offset from the centerline of the bed means there’s some hysteresis that alters the alignment of the bed…I’m always re-adjusting the bed height for the initial Z layer.
I can go a week or so with the printer just being dead-nuts reliable, but if there’s a problem, it’s nearly always related to Z movement.
Ive been thinking about a belt driven Z lift recently. Vertically aligned belts to lift the Z axis, one belt each side of build platform. Idler pulleys at the top, with driving pulleys at the bottom. The driving pulleys will be fitted to each end of a single shaft lying horizontal at the bottom of the printer. The shaft would be driven via a worm and wheel gear. Should be hi-res and accurate, but with the benefit of no drop when motors are off.
Jason - that sounds very similar to the solution as (sort of) shown above. I couldn’t find a printed worm drive that was suitable and proven so was going to use direct drive, at least to begin with. It’s a simple and cheap solution but given comments above by Mike Miller I’m inclined to try for something with less room for ‘fiddly’.
