I've searched everywhere for a bit more depth into the Serial.readBytes() in the library
I’ve searched everywhere for a bit more depth into the Serial.readBytes() in the library with no avail. Where in the library code can I find this?
https://github.com/FastLED/FastLED/wiki/Controlling-leds#read-rgb-data-from-serial
Serial is a standard, arduino supplied library - http://arduino.cc/en/reference/serial
Serial.readBytes() is part of the standard Arduino serial library. http://arduino.cc/en/Serial/ReadBytes
Ok, that’s all I could find through Google. Do you think this library will interfere with FastLED? https://github.com/scogswell/ArduinoSerialCommand
Unlikely to interfere with FastLED, however if it relies on interrupts to do its work, depending on the led chipset you are using FastLED might interfere with it.
It has the ability to use SoftwareSerial() but I can default the library to compile as Hardware Serial instead.
I was actually just looking into doing serial control for my LEDs tonight as well. This library is a great find. I’ll be testing this later this week. Hoping to centrally control 3 teensy’s running 8 strips each.
@Randal_B Were you planning to be wireless or strapped to a computer?
wired: raspberry pi > usb hub > 3or4 teensy
