I've started looking at some of the built in things that FastLED can do,
I’ve started looking at some of the built in things that FastLED can do, and I wonder if it’s possible to replace this code:
void fire(int grnLow) {
for (int grnPx = grnHigh; grnPx > grnLow; grnPx–) {
leds[onLedNumber] = CRGB(redPx, grnPx, bluePx);
FastLED.show();
delay(fDelay);
for (int grnPx = grnLow; grnPx < grnHigh; grnPx++) {
FastLED.show();
delay(fDelay);
with something that uses EVERY_N_MILLISECONDS and fadeLightBy to achieve the same without using any delay() so that I can get non-blocking code?
Basically it is pulsing the green value up and down by a calculated amount.
How long is the delay? Is it variable or set? I’m just trying to think how it might be reworked.
Also where is this routine being called in the main loop? Can you post the code to pastebin or gist?
@marmil This is the original code - https://github.com/timpear/NeoCandle/blob/master/NeoCandle/NeoCandle.ino
This is my latest code that works and has the delay removed - http://pastebin.com/fdgK1b3s
I am trying to simplify it as I am now scaling it up to track multiple ‘candles’ that start and end at different times. At the moment I am trying to introduce a timeout function rather than using static variables, but i have a feeling that the EVERY_N_MILLISECONDS could also work
