@jlauer
Hi John I have attempted to configure and follow your instructions on getting the ESP32 wireless Joystick to to work I have flashed the memory and uploaded the joystick and joystick test files and as you mentioned in your video I am getting “noise” when not touching the joystick. this is a small portion of the console output
dofile(“joystick_test.lc”)
Initting joystick pins. X: 6, Y: 5, Switch: 32
e[0;32mI (9345) gpio: GPIO[32]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m
Set interrupt for switch.
Got xy change. x: 1882 y: 1858
Got xy change. x: 1875 y: 1863
Got xy change. x: 1873 y: 1858
Got xy change. x: 1879 y: 1859
Got xy change. x: 1879 y: 1863
Got xy change. x: 1879 y: 1858
Got xy change. x: 1873 y: 1854
Got xy change. x: 1871 y: 1850
Got xy change. x: 1881 y: 1857
Got xy change. x: 1872 y: 1850
Got xy change. x: 1877 y: 1858
Got xy change. x: 1878 y: 1856
Got xy change. x: 1879 y: 1860
Got xy change. x: 1876 y: 1858
Got xy change. x: 1877 y: 1859
node.restart()
node.restart()
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0008,len:8
load:0x3fff0010,len:4436
load:0x40078000,len:11080
load:0x40080000,len:252
entry 0x40080034
e[0;32mI (45) boot: ESP-IDF v3.0-dev-20-g9b955f4c 2nd stage bootloadere[0m
e[0;32mI (45) boot: compile time 15:47:33e[0m
e[0;32mI (46) boot: Enabling RNG early entropy source…e[0m
e[0;32mI (64) boot: SPI Speed : 40MHze[0m
e[0;32mI (77) boot: SPI Mode : DIOe[0m
e[0;32mI (89) boot: SPI Flash Size : 4MBe[0m
e[0;32mI (101) boot: Partition Table:e[0m
e[0;32mI (113) boot: ## Label Usage Type ST Offset Lengthe[0m
e[0;32mI (135) boot: 0 nvs WiFi data 01 02 00009000 00006000e[0m
e[0;32mI (159) boot: 1 phy_init RF data 01 01 0000f000 00001000e[0m
e[0;32mI (182) boot: 2 factory factory app 00 00 00010000 00100000e[0m
e[0;32mI (205) boot: 3 spiffs unknown c2 00 00110000 002f0000e[0m
e[0;32mI (228) boot: End of partition tablee[0m
e[0;32mI (241) boot: Disabling RNG early entropy source…e[0m
e[0;32mI (258) boot: Loading app partition at offset 00010000e[0m
e[0;32mI (1473) boot: segment 0: paddr=0x00010018 vaddr=0x00000000 size=0x0ffe8 ( 65512) e[0m
e[0;32mI (1473) boot: segment 1: paddr=0x00020008 vaddr=0x3f400010 size=0x20b94 (134036) mape[0m
e[0;32mI (1490) boot: segment 2: paddr=0x00040ba4 vaddr=0x3ffc0000 size=0x0209c ( 8348) loade[0m
e[0;32mI (1520) boot: segment 3: paddr=0x00042c48 vaddr=0x40080000 size=0x00400 ( 1024) loade[0m
e[0;32mI (1544) boot: segment 4: paddr=0x00043050 vaddr=0x40080400 size=0x160dc ( 90332) loade[0m
e[0;32mI (1613) boot: segment 5: paddr=0x00059134 vaddr=0x400c0000 size=0x00064 ( 100) loade[0m
e[0;32mI (1614) boot: segment 6: paddr=0x000591a0 vaddr=0x00000000 size=0x06e68 ( 28264) e[0m
e[0;32mI (1630) boot: segment 7: paddr=0x00060010 vaddr=0x400d0018 size=0x81248 (528968) mape[0m
e[0;32mI (1656) cpu_start: Pro cpu up.e[0m
e[0;32mI (1668) cpu_start: Starting app cpu, entry point is 0x40080fc4e[0m
e[0;32mI (1689) cpu_start: App cpu up.e[0m
e[0;32mI (1701) heap_alloc_caps: Initializing. RAM available for dynamic allocation:e[0m
e[0;32mI (1724) heap_alloc_caps: At 3FFAFF10 len 000000F0 (0 KiB): DRAMe[0m
e[0;32mI (1744) heap_alloc_caps: At 3FFC90E8 len 00016F18 (91 KiB): DRAMe[0m
e[0;32mI (1765) heap_alloc_caps: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAMe[0m
e[0;32mI (1787) heap_alloc_caps: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAMe[0m
e[0;32mI (1808) heap_alloc_caps: At 400964DC len 00009B24 (38 KiB): IRAMe[0m
e[0;32mI (1829) cpu_start: Pro cpu start user codee[0m
e[0;32mI (1895) cpu_start: Starting scheduler on APP CPU.e[0m
Mounting flash filesystem…
e[0;32mI (2035) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSEe[0m
e[0;32mI (2225) phy: phy_version: 355.1, 59464c5, Jun 14 2017, 20:25:06, 0, 0e[0m
I (2225) wifi: wifi firmware version: 72ddf26
I (2225) wifi: config NVS flash: enabled
I (2225) wifi: config nano formating: disabled
e[0;32mI (2235) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSEe[0m
e[0;32mI (2245) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSEe[0m
I (2265) wifi: Init dynamic tx buffer num: 32
I (2265) wifi: Init dynamic rx buffer num: 32
I (2265) wifi: wifi driver task: 3ffd34f4, prio:23, stack:4096
I (2265) wifi: Init static rx buffer num: 10
I (2275) wifi: Init dynamic rx buffer num: 32
I (2275) wifi: Init rx ampdu len mblock:7
I (2275) wifi: Init lldesc rx ampdu entry mblock:4
I (2285) wifi: wifi power manager task: 0x3ffd88bc prio: 21 stack: 2560
NodeMCU ESP32 build unspecified powered by Lua 5.1.4
lua: cannot open init.lua
can you tell me what I need to do to get the stable output you get on your video please
