just brought a second hand 50 w 500mm x 300mm laser cutter that i need the driver for corel draw and a manual,can anyone help
Wouldn’t happen to be the same one that comes with the K40 would it?
Upgraded to corel draw x7 ,found a driver ,need a manual for machine,maim board is dsp controller and can cut files from usb stick,computer usb and nework
@Phillip_Conroy Good news. I wish you good luck getting it to run.
@Phillip_Conroy
Nice name…
I have the same machine. Here’s a shared googe drive folder with all the manuals that I received
I call it a K50 but seems to be referred to as a 350 in the manuals.
https://drive.google.com/drive/folders/0B_KUNLUaXRMoa2ZhN1hvZWNqVEE?usp=sharing
Let me know if I can help with anything.
You need Rdworks
overwhelmed by the dsp control,coming from a k40 i think it will take awhile to learn
Did you get the latest version of RDworks?
Looks like it’s at 8.01.22
how does the PSU look like ? Smoothieable ?
Go rdworks plug in to work with corel draw x7,can cut ok just haven’t figured out etching
all ready installed a amp meter as do not trust % ,turns out 100% is 24ma so somebody has set power supply to this limit.Etches twice as fast as the k40 as etches with laser head moving both left and right,Down side is as laser cutter has been sitting for over 6 months tube is down to only 38 watts-i have read they where never 50 watts anyway…Dsp controller was scary for the first 2 days now i love it
