Just build my first printer. Having problems with communications between the computer and the rambo board. Can’t even get out started. Can someone point me in the right direction to solve this. Thanks in advance.
So you’ve loaded the firmware for marlin. No errors, right? Give me more details about the printer. Maybe post some pictures of the setup board connectors drivers etc.
It not a lot to go on maybe go over everything from the top. The marlin configuration that it’s fight for the board not sure which number the rambo board uses. Also if you have a display and sd card you need to have the right library loaded. Also maybe check the baud settings are the same in your software as what you set it in the firmware.
The com port will show when you connect with the arduino ide. That’s the port your pc detects the board on and it will change if you plug into another port. The other thing with arduino if you connect power before the USB it doesn’t always show up. So disconnect the USB and power then connect USB before power.
Maybe try pronterface or repetier to connect. It gives much more detail than cura. As far as the connection goes. You can slice it in cura and print with one of the others if you want. But it’s very hard to troubleshoot without seeing the setup
