Uncured resin is basically light-sensitive superglue. It’s going to be unpleasant because it has to be highly chemically reactive in order to do what it does. You can’t get away from that.
@Florian_Ford Studies show the prints leach raw uncured chemical. For example, if you put an SLA print in a fish tank, the fish will gradually die off. The final cured polymer is safe, but it’s impossible to get it to 100.0000% cure.
I would never handle the raw resin or prints in the “green” state (just of of the printer) without gloves… all SLA prints should be properly post-cured in a UV chamber before handling.
