Just curious, what needs to be modified in Marlin for it to support homing to max endstops for a CoreXY machine (at least Z-max)?
Currently, homing to max endstops is disabled because of compatibility issues with the endstop checking routine, but I’d prefer if the machine homed to x-min, y-max, and z-max
Here is those endstop settings in configuration.h what I think effects to this situation. I don’t have XY endstops so please don’t pay attention to their settings.
With these settings my H-bot printer homes Z-axis to the lowest point(max lenght) and with “travel limits after homing” I can adjust the distance between bed and nozzle.
#ifndef ENDSTOPPULLUPS
// fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN
// #define ENDSTOPPULLUP_ZMIN #endif
#define INVERT_X_DIR true // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
// Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR 1
