Just downloaded FastSPI2 for the first time (RC3).
Just downloaded FastSPI2 for the first time (RC3). I’m trying to control 5m of WS2811 pixels and getting some flickering at the in the last ~20 pixels. I have 5V/GND/data at one end and 5V/gnd connected at the other end, which makes me think it’s a data line problem. Shouldn’t I be able to send data this far without flicker or am I missing something?
What are you using as a controller?
Also - sometimes, with longer lengths of ws2811’s, I have found some help in grounding the data line at the far end of the strip (just connecting data to ground).
… or run it through a series resistor like what I ended up doing with my LPD8806s … tying them to ground didn’t fix the problem, but the series resistor did.
I’m using a Teensy 3.0. I had put a 100 ohm resister in series with the data line but hadn’t connected data to ground. Thanks for the suggestion, that fixed it!
Yeah, it’s probably different for each driver. I too started with simply connecting the data and clock lines to ground at the end of the string, but that actually made it worse. In a normal scenario, there should be resistors in series with those lines when you reach a certain length and then connect them to the next string. So since I’m not connecting to “the next string”, I pulled them down to ground with the resistors. That solved the problem.
