Just finished my biggest multi part print so far… is the Omolon Kamakatok HC4 from https://www.myminifactory.com it’s also the first print i ever painted… (working on my painting skills but for a first try)
For that weathered or used look you can do a wash of very thinned black paint, then dry brush gunmetal / silver to bring out the details…
@PrintinAddiction thanks, i AM still figering out the Order in witch to do the painting… Needs more practisch
Nice print. Very good detail on the small holes in the barrel.
Ergononmics?
@Sean_Blackstone what do you mean with Ergononmics?
@Imko_Beckhoven_van How does it ‘feel’ when you hold it or use it? Is it comfortable. Functional?
@Sean_Blackstone
ah ok, it’s not functional. The grip shape is great but for my hand’s it coud be a bit longer. Although there are 2 treaded rods inside witch help for weight it feels light and the blance is slightly off. If you can add more weight to the handel. I printed with 3 perimeters so it feels solid and strong. Hope this helps.
