Just had a random idea pop in my head for a suggestion for LaserWeb.
Not sure how practicable this would be to implement, but would it be possible to create a CAM operation for Laser V-Carve, where it creates offset gcode around the original (on either side), offset by whatever the laser beam diameter is (or user chosen offset)?
Then, allow user to set a “width” field, which specifies how far out from the original gcode the V will spread (e.g. 2.5mm = 2.5mm on either side of the original, for total of 5mm).
So, for each offset line away from the original it will decrease in power from the max power level set for the original line down to 0% at the outer offset (so thus giving a stepped/V effect).
Also, an inverse V-carve feature where the original line is 0% power & offset lines work their way progressively higher (up to the max power level that is set in the operation)?
edit: I know technically we could use Laser Cut Inside & Laser Cut Outside with a bit of playing around, but was thinking a one click automated setup would be nice to play around with.
