Just looking for help. my printrbot jr stopped connecting at all. I posted on here and was directed to instructs on how to reflash the firmware. When I did it, I got this error message
error while checking the flash was erased<<<
Anyone familiar with this?
@boog_nish just out of interest have which board is it as to flash some boards you need to short the jumpers on others they need to be open.
And push the reset button just in case…it may work.
Erasing flash memory is not the end for this board. Have you looked at the Printrboard entry on the reprap wiki? http://reprap.org/wiki/Printrboard You may have to flash the bootloader and firmware.
Even if you do have a damaged board at this point, you can still use the Printrboard trade in program to get a new one for $10.
@Nigel_Dickinson . Even the walkthru steps while using the firmware updater says 'if it is a revision D or later then place a jumper on the BOOT pins. I am prone to misunderstanding, but this is seemingly clear. ??
