Just now starting to finish my build, and ran into an odd problem.
Anyone with an M1 Pro board run into an issue where the limit switches are open when the system is powered off, but close once the board is powered up?
I can’t home right now because the system thinks it is hitting the limit switches in 2 of my axis. The only thing different about them is that the one axis has isolated wiring, I didn’t run it through the stepper bundle.
Any ideas, I am running the limit switch wires through a ferrite ring, maybe I should run the stepper motors through one?
